Gasbarre supplies box furnace system to US-based aerospace company
The Gasbarre high temperature box furnace line is custom designed to meet the customer’s strict process requirements, manufacturing methods, and eliminates the need for a quench pit. (Courtesy: Gasbarre)
Gasbarre Thermal Processing Systems recently manufactured and commissioned a high temperature box furnace line for an aerospace company in the U.S. Midwest.
The system is custom designed to meet the customer’s strict process requirements, manufacturing methods, and eliminates the need for a quench pit. The equipment will process 36” wide by 48” long by 24” high workloads, weighing up to 2,000 pounds, and will be used for solution treating of high alloy forgings. The single zone electrically heated furnace is designed with multiple trim zones to meet AMS 2750 temperature uniformity requirements across a wide temperature range and allows for fast furnace recovery times. The system is equipped with both a water quench tank and air-cooling station which provide process flexibility in a single system. Material handling is done through a pick-and-place manipulator to improve fixture life. The manipulator’s fully automated cycles enable the system to consistently meet strict time to quench requirements.
Gasbarre Thermal Processing Systems, in Plymouth, Michigan, has been designing, manufacturing, and servicing a full line of industrial thermal processing equipment for more than 40 years. Gasbarre’s product offering includes both batch and continuous heat-processing equipment and specializes in temper, tip up, mesh belt, nitriding, box, car bottom, pit, and vacuum furnaces as well as a full line of replacement parts and auxiliary equipment which consists of atmosphere generators, washers, quench tanks, and charge cars. Gasbarre continues to service and support J. L. Becker brand equipment and custom designs and manufactures thermal processing equipment to meet customer’s specific needs.
MORE INFO  www.gasbarre.com
