Grieve oven No. 944 is a 750°F electrically heated cabinet oven currently used for sintering operations at a customer’s facility.
Workspace dimensions measure 44”W x 30”D x 60”H. 30kW installed in Incoloy-sheathed tubular heating elements heat the oven, while a 2000 CFM, 2 HP recirculating blower provides a horizontal airflow to the workload.
The Grieve cabinet oven features 6” insulated walls, aluminized steel exterior, Type 430 stainless steel interior, and four 20”W x 28”H independent doors for easy access to the workspace. Eight removable loading pans are provided for each door compartment (32 pans total).
No. 944 has a digital-indicating temperature controller, manual reset excess temperature controller with separate contactors, and 10” diameter circular chart recorder onboard. In addition, four timers, each with a pilot light and door interlock, are included to individually time the heating process in each compartment.
MORE INFO www.grievecorp.com
