Grieve offers 2,200º F electric inert atmosphere furnace
No. 854 is a special high-temperature, 2,200º F electrically-heated, inert atmosphere floor furnace from Grieve.
The oven is currently used for various heat-treating applications at a customer’s facility.
Workspace dimensions measure 24” wide x 48” deep x 24” high. 53KW installed in heavy-gauge, high-temperature Kanthal AF alloy wire, rod overbend design heaters provide maximum operating temperatures to 2,200º F.
This Grieve furnace features 9” insulated walls, consisting of 4 ½” thick 2600o F firebrick, 2 ½” thick 2,300º F firebrick and 2” thick block insulation. A firebrick plate hearth is supported on firebrick piers. An electrically-operated vertical lift door is provided, with remote foot pedal control.
Special inert atmosphere construction on No. 854 includes a continuously welded outer shell, high-temperature door gasket, sealed heater terminal boxes, inert atmosphere inlet, outlet, and flowmeter.
Safety and control equipment on-board this Grieve furnace include a digital indicating temperature controller, manual reset excess temperature controller with separate contactors and a four-channel strip chart recorder.
MORE INFO  www.grievecorp.com
