Lucifer Furnaces supplies convection oven for heat-treating stainless steel
Lucifer Furnaces supplied a forced-air recirculating oven to a manufacturer of medical and aerospace parts.
The model 42-M36 will be used to heat treat 17-4 stainless steel. (Courtesy: Lucifer Furnaces)
Model 42-M36 will be used to heat treat 17-4 stainless steel.  With a chamber size of 12”H x 18”W x 36”L, powered with  13KW, the oven heats quickly with side-mounted element holders housing coiled, low-watt density resistance wire.  Standard features include heavy gauge sheet steel construction, 4 ½” multilayer insulation, a 16-gauge stainless steel liner, and a horizontal swing door with safety switch. A rear-mounted high-volume fan directs air past heating elements, then throughout the work chamber for uniform heating.  This convection style oven is equipped with a programmable controller and 2-pen chart recorder.
FOR MORE INFORMATION: www.luciferfurnaces.com
