Wisconsin Oven Corporation manufactured a natural gas-fired enhanced duty walk-in oven for a transportation technology company. This is a repeat customer for Wisconsin Oven and the industrial oven will be used for heat treating baskets of aluminum parts.
The heat-treating oven has a maximum temperature rating of 315°C (600°F) and work chamber dimensions of 6’0” wide x 15’0” long x 6’0” high. The equipment has sufficient capacity to heat 5,952 kg (1,312 pounds) of aluminum from 21°C (70°F) to 250°C (482°F) within 120 minutes when loaded into an ambient oven.
The industrial oven is designed with a vertical lift, pneumatically operated door and a 12-gauge aluminized floor. A powered load car rated at 13,125 pounds will be used to load and unload the oven. The body is constructed with industrial board type insulation with a 1,200°F service temperature rating. Guaranteed temperature uniformity of ±3°C (5.4°F) at 250°C (482°F) was documented with a standard nine (9) point profile test conducted in an empty oven chamber under static operating conditions.
“At Wisconsin Oven, a large portion of our business is from repeat customers. We focus on providing excellent customer service each step of the way, from the time we take the first call to after the equipment is installed and operational. It is that ongoing dedication to our customers that keeps them coming back,” said Nick Toci, sales engineer.
Unique features of this walk-in oven include:
- Programmable controller with batch tracking software and Ethernet capabilities
- Digital chart recorder
- 1,600,000 BTU per hour
- 12-gauge aluminized floor
- Two (2) 22,000 CFM @ 20 HP blowers
- Powered load car rated at 13,125 pounds
- Guaranteed temperature uniformity of ±3°C (5.4°F) at 250°C (482°F)
This heavy duty walk-in oven was fully factory tested and adjusted prior to shipment from our facility. All safety interlocks are checked for proper operation and the equipment is operated at the normal and maximum operating temperatures. An extensive quality assurance check list was completed to ensure the equipment met all Wisconsin Oven quality standards. This equipment is backed by Wisconsin Oven’s Exclusive and Unprecedented 5-Year WOW™ warranty (parts only).
MORE INFORMAtiON www.wisoven.com
