Lindberg/MPH offers electrically heated box furnace
This box furnace can be used for applications that require process temperatures up to 1,850°F under a N2/H2 blended atmosphere (96/4 blend). (Courtesy: Lindberg/MPH)
Lindberg/MPH has a new electrically heated atmosphere box furnace with a semi-automatic powered load/unload transfer table and oil quench tank in stock. This box furnace can be used for applications that require process temperatures up to 1,850°F under a N2/H2 blended atmosphere (96/4 blend). This equipment has never shipped from our manufacturing facility, includes our full 1-year warranty, and is available for immediate inspection or shipment.
Specifications of this Lindberg/MPH furnace:
  • Designed to accept a 24” W x 36” D x 18” H basket.
  • Total furnace heat input: 45 KW with SCR power control.
  • Max temperature: 1,850°F.
  • Capacity (gross load): 900 lbs. @ 1,850°F.
  • Furnace shell is 3/16” thick welded steel with high-temperature insulating firebrick lining.
  • 2 HP recirculating fan.
  • Air operated furnace door and quench elevator with 3-way hand control valve.
  • Control Panel w/ PLC, HMI, & digital recorder included.
  • Utilities required:
  • 480/3/60; Approximately 100 FLA.
  • Compressed air @ 90 PSIG.
  • Cooling water @ 30 PSIG (70°F).
  • N2/H2 @ 30 OSIG (blending panel incl.).
  • Price: $315,000.
  • Model Number: 11-RO-243618-18AF.
MORE INFO  www.lindbergmph.com
