The maximum temperature rating for this furnace is 1,100°C and has a work chamber of 36" W x 48" D x 36" H making it ideal for heat treating a variety of part sizes. The atmosphere box furnace has a wide temperature range of 760°C to 1,100°C. The heat-treating furnace is constructed with mild steel construction and structural steel frame. A vacuum-formed ceramic fiber insulation is used for quick heat-up and low heat storage. A horizontal swing insulated plug door keeps the inner hot surface away from the operator when opening to charge or unload work. The programmable temperature controller is capable of running 50 programs with 500 segments. This capability allows the operator to set specific programs for the different parts that will be processed.
“By designing the furnace with a wide temperature range, it provided the customer with the flexibility to process a variety of part sizes,” said Jason Dobberstein, Lindberg/MPH sales manager.
Features of this Lindberg/MPH heat-treat furnace include:
- Vacuum-formed ceramic fiber modules with low heat storage for fast heat-up rates
- Prewired, side-mounted, forced air-cooled control console
- Programmable controller
- Vacuum-formed ceramic fiber insulation
- Horizontal swing insulated door plug
- Door limit switch
- Nitrogen atmosphere
This box furnace is CSA inspected and certified. All Lindberg/MPH equipment comes with an exclusive three-year warranty, which covers all materials for all components (less wear items).
FOR MORE INFORMATION: lindbergmph.com
