Premier/BeaverMatic ships two spray/dunk washers
Operators have the option of running the Premier/BeaverMatic spray/dunks washer systems in either full automatic mode for production, or in manual mode, for set-up and diagnostic purposes. (Courtesy: BeaverMatic)
Premier/BeaverMatic spray/dunk washers were recently manufactured and shipped from Premier’s new 40,000 Ft² manufacturing facility in Farmington Hills, Michigan.
The repeat customer is an international aerospace firm, with a facility in the southeastern United States. The spray/dunk washers are designed to clean 1,250 pounds of heat-treated material, using both a full immersion oscillating dunk cycle, propeller agitation, and also using a separate high-pressure, with solution, spray cycle. The washers are fabricated entirely of type 304 stainless steel, and feature safety light curtains, powered access doors, electric heating, automatic water make-up, liquid level switches, and extensive heat shielding as well as guarding to protect plant personnel from incidental contact with hot surfaces.  Additionally, the washers are equipped with Allen Bradley PLC’s and HMI’s, SmartSkim Crossflow Oil Separators, and SBS Smart Dual Bag Filtration System. Operators have the option of running the systems in either full automatic mode for production, or in manual mode, for set-up and diagnostic purposes.
MORE INFO  www.beavermatic.com
