TPS ships Gruenberg explosion resistant truck-in oven
This Gruenberg walk-in oven has a maximum temperature rating of 138°C with work chamber dimensions of 31” W x 68” D x 72” H. (Courtesy: Thermal Product Solutions)
Thermal Product Solutions, a global manufacturer of thermal-processing equipment, announced the shipment of one Gruenberg explosion resistant truck-in oven to the defense security industry.
This Gruenberg walk-in oven has a maximum temperature rating of 138°C with work chamber dimensions of 31” W x 68” D x 72” H. The Gruenberg oven was constructed from a structural steel frame that supports the stainless-steel interior chamber liner and the exterior sheet metal. All interconnecting struts are non-continuous, which keeps the exterior cool.
The front-loaded explosion resistant oven used a horizontal airflow, which maximizes heating rates and temperature uniformity of the product load. Two circulation blowers are in a conditioning plenum chamber on the rear of the oven. The blowers direct air through perforated panels on one side of the chamber and flows horizontally across the product. The air exits the work chamber on the opposite wall back through the steam coil for reheating and recirculation.
“Gruenberg products are designed to meet the highest standards of safety specifications. This truck-in oven was designed to accommodate wet batches between 5-2,000 pounds of product and up to 1,000 pounds of water,” said Denny Mendler, Gruenberg product manager.
Features of this Gruenberg walk-in oven include:
  • Steam heat.
  • Explosion resistant construction.
  • Interior incorporates intrinsically safe design features.
  • Special Teflon, Nylon and Gore tape to eliminate metal to metal contact.
  • Fully welded 3304L stainless steel interior liner.
  • Dye tested full penetration welds.
  • Powered exhaust.
  • Air exhaust HEPA filter.
  • Intake air pre-filter.
  • Intake air HEPA filter.
  • Analog dial thermometer.
  • Teflon truck spacers.
  • Special loading trucks with non-metallic corner bumpers and shelf slides.
More info  www.thermalproductsolutions
